Lock-ups on MCS-7825 after after OS Upgrade to 2000.4.4aSR6
johnnylingo
Level 5
Level 5
About 3 weeks ago, I upgraded some MCS-7825 & MCS-7835 servers to 2000.4.4aSR6. Since then, one of the 7825's has been rebooting on its own almost twice a day. The other 7825 and 7835s are operating fine.
Anybody else encountering a problem with this? I see in the release notes, some BIOS and firmware updates are included for the 7825, and am suspecting this is the problem.
6 Replies 6
espereir
Level 5
Level 5
Do you have any related errors on the App or Sys logs? Do you have a DrWatson crash file that we can check?
Brad Martin
Level 3
Level 3
I just ran into the same problem with 7835 moving from 4.4aSR4 to 4.5bSR3. Did you ever find a solution?
My problems actually turned out to be hardware, I think. I reviewed the logs and found out it had been happening for several months.
Did you get a blue screen before the reboot? Did the errors show in event logs?
Event logs showed the reboots had been happening ever since the server was installed by a vendor, about 3 times a week.
Ok. Thanks.
