10-10-2002 10:38 PM - edited 03-12-2019 09:07 PM
I'm using VOIP (from a non cisco provider) over the WAN (leased line),I configured the serial interface as follows:
interface Serial1/0
bandwidth 128
no ip address
encapsulation frame-relay
frame-relay intf-type dce
interface Serial1/0.1 point-to-point
description voice
bandwidth 80
ip address 192.168.1.1 255.255.255.252
traffic-shape rate 80000 8000 8000 1000
frame-relay interface-dlci 100
interface Serial1/0.2 point-to-point
description data
bandwidth 48
ip address 192.168.3.1 255.255.255.252
traffic-shape rate 48000 7968 7968 1000
frame-relay interface-dlci 101
I devided the interface to 2 subinterfaces :one for voice packets and the other for data.
I'm experiencing some problems on the telephones (discontinous dialogue) when I run the PC anyware Application or an ACCESS replication.
The results of the show interface s1/0 shows :
Antelias#sh inter s1/0
Serial1/0 is up, line protocol is up
Hardware is PowerQUICC Serial
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
reliability 255/255, txload 93/255, rxload 65/255
Encapsulation FRAME-RELAY, loopback not set
Keepalive set (10 sec)
LMI enq sent 24364, LMI stat recvd 24364, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 8122/0, interface broadcasts 0
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d19h
Queueing strategy: fifo
Output queue 0/40, 18275 drops; input queue 0/75, 0 drops
5 minute input rate 33000 bits/sec, 52 packets/sec
5 minute output rate 47000 bits/sec, 52 packets/sec
1862064 packets input, 194092712 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1989966 packets output, 161007854 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
I noticed that I have the problem even when I just have one call only.
10-16-2002 08:41 AM
I would only suspect the codecs that you are using. If you are using G711 then you need more bandwidth for voice.
11-02-2002 10:07 PM
The traffic shaping is not optimised for VOIP applications. You need to use frame relay traffic shaping, not the generic traffic shaping that is currenlty applied. You need to apply Low latency queueing to match on the voip traffic and prioritise it. Finally, you need to fragment the traffic at layer 2 to allow the smaller voip packets to be interleaved between the upper layer fragments. Have a look at the following URL for some background -
When setting up the LLQ, it would be useful to know the specific UDP port numbers the application is using so this can be configured in the access list that matches on the traffic types.
cheers
Paul Cameron
