Max Phones exceeded - ISR4351
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a solution with CUCM 10.5.2 and in the remote site there is a gateway ISR 4351. Today, this remote site lost the connection with Main Site, then any IP Phone go to SRST Mode, but, any phones presented the message: "Max Phone exceeded" in display. In read any posts, but, not stay clear for me if this problem is related the configuration, hardware resources or license.
Could help me, please,
Wilson
5 Replies 5
R0g22
Can you share "show run" and "show license all" from the router ?
Hi Nipun,
Thanks a lot for Your contact. Follow the configurations:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.03.27 17:36:05 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 13606 bytes
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname XPTO_VGW
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
aaa session-id common
clock timezone GMT -7 0
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name XPTO.COM
subscriber templating
voice service voip
 ip address trusted list
  ipv4 192.168.83.0 255.255.255.0
  ipv4 192.168.104.1
  ipv4 192.168.104.2
  ipv4 192.168.0.24
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service media-renegotiate
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  session transport tcp
  registrar server expires max 600 min 60
  asserted-id pai
  midcall-signaling passthru
  g729 annexb-all
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice class sip-profiles 1
 request REINVITE sdp-header Audio-Attribute modify "inactive" "active"
 request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
 request REINVITE sdp-header Connection-Info modify "0.0.0.0" "192.168.5.74"
 request REINVITE sdp-header Audio-Connection-Info modify "0.0.0.0" "192.168.5.74"
 request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
voice class sip-profiles 2
 request REINVITE sdp-header Connection-Info modify "0.0.0.0" "192.168.89.5"
 request REINVITE sdp-header Audio-Connection-Info modify "0.0.0.0" "192.168.89.5"
 voice class e164-pattern-map 2
 description CARRIER - PTA DID Ranges
  e164 2.......
  e164 9...
voice class e164-pattern-map 1
 description DIDs from CARRIER
  e164 +5.............
voice register global
 default mode
 no allow-hash-in-dn
 timeouts interdigit 5
 system message MODO BACKUP
 max-pool 40
voice register pool  1
 translation-profile incoming SRST-IN
 id network 8.0.0.0 mask 255.0.0.0
 dtmf-relay rtp-nte sip-notify
 voice-class codec 1
 no vad
voice-card 0/4
 dsp services dspfarm
 no watchdog
license udi pid ISR4351/K9 sn FFFFFFFFFFF
username xpto privilege 15 secret 5 $1$CS5x$35eMovD/faOXLeTF4h877/
username admin privilege 15 secret 5 $1$q3UO$MQMKMy42JXXkGq.vs0USA1
redundancy
 mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
 description CARRIER SIP RTR
 ip address 192.168.5.74 255.255.255.252
 negotiation auto
interface GigabitEthernet0/0/1
 description CORE SW Gi1/0/15
 ip address 192.168.89.5 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface Service-Engine0/4/0
 no ip address
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 192.168.89.1 name Firewall-DMZ-SIP
ip route 192.168.0.24 255.255.255.255 192.168.5.73
ip route 192.168.0.102 255.255.255.255 192.168.5.73
ip route 192.168.5.73 255.255.255.255 GigabitEthernet0/0/0
ip tacacs source-interface GigabitEthernet0/0/1
ip access-list standard SNMP_SERVERS
 permit 172.16.240.170
 permit 10.20.18.16
 permit 172.16.104.5
 permit 10.20.18.17
 permit 10.20.18.15
 permit 172.16.241.197
 permit 172.16.223.27
 permit 172.16.226.14
 permit 172.16.240.8
 permit 172.16.240.76
 permit 172.16.241.68
 permit 172.16.241.67
 permit 172.16.229.48 0.0.0.7
 permit 172.16.198.80 0.0.0.15
 deny   any log
logging trap notifications
logging source-interface GigabitEthernet0/0/1
logging host 172.16.206.60
logging host 172.16.105.85
snmp-server community traps RO SNMP_SERVERS
snmp-server community h0tsauce RO SNMP_SERVERS
snmp-server location Parkinson Avenue
snmp-server system-shutdown
snmp-server enable traps tty
snmp-server enable traps syslog
snmp-server host 172.16.226.14 traps
snmp ifmib ifindex persist
tacacs-server host 172.16.198.120
tacacs-server host 10.20.18.13
tacacs-server directed-request
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/1
sccp ccm 192.168.104.1 identifier 2 version 7.0
sccp ccm 192.168.104.2 identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 5 register PT160_729R8_MTP
 associate profile 4 register PT160_711A_MTP
 associate profile 3 register PT160_711U_MTP
 associate profile 2 register PTA_PT160_XCODE
 associate profile 1 register PTA_PT160_CFB
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
 dspfarm profile 2 transcode
 codec g729aPT8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g729PT8
 maximum sessions 3
 associate application SCCP
dspfarm profile 1 conference
 codec g729PT8
 codec g729r8
 codec g729aPT8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 3
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions software 100
dspfarm profile 4 mtp
 codec g711alaw
dspfarm profile 5 mtp
 codec g729r8
dial-peer voice 110 voip
 description Outbound calls to PSTN
 translation-profile outgoing PSTN-OUT
 destination-pattern 0T
 session protocol sipv2
 session target ipv4:192.168.0.102
 session transport udp
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 voice-class sip early-offer forced
 voice-class sip profiles 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte sip-kpml
 no vad
dial-peer voice 150 voip
 preference 1
 modem passthrough nse codec g711ulaw
 session target ipv4:192.168.104.2
 destination e164-pattern-map 1
 voice-class codec 1
 voice-class sip profiles 2
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 fax rate 14400
 fax protocol pass-through g711ulaw
 no vad
dial-peer voice 250 voip
 preference 2
 session target ipv4:192.168.104.1
 voice-class codec 1
 fax rate 14400
 no vad
dial-peer voice 1000 voip
 description Outbound calls from UCM
 translation-profile incoming XPTOPLUS-IN
 incoming calling e164-pattern-map 1
 voice-class codec 1
 no vad
dial-peer voice 1001 voip
 description Inbound calls from CARRIER
 translation-profile incoming PSTN-IN
 incoming called e164-pattern-map 2
 voice-class codec 1
 no vad
dial-peer voice 111 voip
 destination-pattern 9[72][47]T
 voice-class codec 1
 no vad
sip-ua
 retry invite 2
 timers trying 300
 g729-annexb override
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 192.168.89.5 port 2000
 max-ephones 40
 max-dn 80
 system message primary SRST MODE
 dialplan-pattern 1 27.. extension-length 4
 conference transfer-pattern
 call-forward busy 2700
 call-forward noan 2700 timeout 30
 time-format 24
 date-format dd-mm-yy
XPTO_PT160_VGW#sh license all
License Store: Primary License Storage
StoreIndex: 0  Feature: uck9                              Version: 1.0
 License Type: Permanent
 License State: Active, In Use
 License Count: Non-Counted
 License Priority: Medium
StoreIndex: 1  Feature: ipbasek9                          Version: 1.0
License Store: Built-In License Storage
StoreIndex: 0  Feature: appxk9                            Version: 1.0
 License Type: EvalRightToUse
 License State: Active, Not in Use, EULA not accepted
     Evaluation total period: 8  weeks 4  days
     Evaluation period left: 8  weeks 4  days
     Period used: 0  minute  0  second
 License Priority: None
StoreIndex: 1  Feature: uck9                              Version: 1.0
 License State: Inactive
StoreIndex: 2  Feature: securityk9                        Version: 1.0
StoreIndex: 3  Feature: FoundationSuiteK9                 Version: 1.0
StoreIndex: 4  Feature: AdvUCSuiteK9                      Version: 1.0
StoreIndex: 5  Feature: cme-srst                          Version: 1.0
 License Type: RightToUse
 License Count: 80/0  (In-use/Violation)
 License Priority: Low
StoreIndex: 6  Feature: throughput                        Version: 1.0
Thanks a lot,
Best Regards,
Wilson
Your SCCP and SIP CME are configured to support 40 IP Phones each. This can also be seen from the license in-use output -
How many phones did not register vs total available phones ? Phones were SIP or SCCP or a mix of both ?
Hi Nipun,
In the site we have 53 IP Phones, all are SIP. About the IP Phones not registered when entered in fallback mode, I don´t have this information. 40 is the maximum IP Phone that will to register when the site enter in Fallback mode? This is a hardware limitation for this specific gateway model or is possible to configure more IP Phones with hardware/software version?
Wilson
40 is not the hardware limitation. ISR 4351 will support I believe around 250 IP phones, SIP and SCCP included. You need to configure a higher value for max-pools under voice register global in order to accommodate all 53 phones.
