MCS-7825-H1-IPC1 with OS 2000.27 Problem
pvhoa
Dear All,
I have problem on the MCS-7825-H1-IPC1 follow:
- CCM4.1 included OS2000 2.7
- RAID 1 is configured
after that, I insert disk1(hardware detection)for install OS on the MCS and alert "This Os version dose not support the detected server"
Pls help in this case
thanks in advance
11 Replies 11
p-kitaka
You need OS2000.4.1, it installs using a single disk. The hardware detection disk is not needed.
My Company is order Cisco MCS-7825-H1-IPC1 and CCM4.1 included only OS2000.2.7, I can't received OS2000.4.1
Have you link download OS2000.4.1?
thanks
I have gone the way of the 2000.4.1, the disk loads the nthe server reboots ad just sits there. Are there additional tasks that need to be accomplished to get this thing to fire up?
I have received an OS2000_4_1-H1.ISO file with the size 888MB, then I burned image to DVD ROM.
After that, I insert into the MCS7835-H1, however the CD can not boot for setup.
Dear HOA PHAM VAN ,
I also have same problem as you. Would you please let me know how can i receive 2000.4.1 OS Image? can i get it from you? Please help me.
Saeed.
Hi Saeed,
i will upload image.ISO to you. pls re-send to email pvhoa@globaleis.com
thx
I have the same problem
My Server is: MCS-7825-H1-IPC1 and I need the OS 2000.4.1
Where can I download it ?
Mohamed
I have the same problem, I can't find any bugs or field notice from Cisco that indicate OS 2000.2.7 is not supported.
If you look at the manual that comes with the discs for 2000.2.7 it will show that 7825-H1s and I1'sare not supported.
If you ordered the right discs (CM4.1-k9- 7825-H1) or (CM4.1-k9-7825-I1) You should have the appropriate discs for 2000.4.x in the bundle.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I have one CD named Installation and Recovery 2000.4.1 DVD for MCS-7825-H1
Is this is the correct CD to detect my Server MCS-7825-H1 Server ?
Do I need any additional CDs ?
Mohamed
