MCS7835 BIOS UPGRADE PROBLEMS
pmarovino
I'm trying to perform a BIOS upgrade on 2 different MCS7835. The file used is 7835-BIOS-04-02-01.exe (downloaded from CCO - It seems to me that there are no differences between files present in CM 3.0 & 3.1 pages).
The systems have the following original BIOS:
P17 09/27/2000, P17 11/08/2000.
The first system was already updated when I installed the CCM 3.05; the latter was never updated.
RESULT: I'm not able to upgrade the new BIOS, I get the error
FLASHING PROGRAMMING LOCKED! COLD BOOT OF SYSTEM IS NECESSARY TO UNLOCK CORRECT ADMINISTRATOR PASSWORD IS NECESSARY IF ONE HAS BEEN SET.
I never set any kind of password on both BIOS.
- Does anyone have encountered this problem before??
- Is the BIOS upgrade mandatory to pass from 3.0 to 3.1??
paolo.marovino@getronics.com
Sascha Monteiro
Level 6
Level 6
Did you do a cold boot? (no reboot with floppy, but shutdown, put floppy in and power on)
This is nessecary!
Good luck,
Sascha
Sascha,
thank you very much, it works fine!!!
Thanks again for the support
Paolo
