10-04-2011 02:50 AM - edited 03-13-2019 07:33 PM
We are using MP 8 with WebexNode for mcs, when opening a meeting, we always have to check the box 'allow external participants' otherwise we are disconnected from the meeting.
Can anyone suggest what setting may be causing this please.
Cheers
Rich
10-04-2011 06:00 AM
It sounds like the default setting is for internal meetings. This is set on your WebEx admin Settings page. The URL is your WebEx site/admin. Click on the Site Settings on the left and partway down the screen check the Default MP external attendee check box. Then when a meeting is scheduled by default it will be external.
Hope this helps
John
10-05-2011 12:26 AM
Hi John
Thanks for the reply
We dont have Default MP external attendees (MC only) checked, but have now changed this, thankyou.
I will try to explain a little clearer:
As a MP and Webex user, when I create a meeting on the Webex cloud, as soon as I start the meeting,
I am disconnected from my own meeting, the only time I can stay connected is if I enable the check box 'allow external participants'.
The question is, what am I missing in my config that treats me as an external participant or is this normal behaviour of the system?
Cheers again
Rich
10-05-2011 06:11 AM
Rich,
This is not normal behavior. I am not sure what is causing this problem so need to understand a little more about your environment.
I assume you have a WebEx Node for internal meetings and the internal meetings work OK? Now with the above mentioned check box checked all meetings default to the being external in the cloud though you can still schedule internal meetings.
Does your WebEx support SSO and integrated with MP for security and profile maintenance?
Are you on the network when you try to join these meetings?
Can you sign-in as the host?
If you have the WebEx Node you have internal licenses?
Sorry for all the questions.
John
