08-30-2004 05:55 PM - edited 03-13-2019 06:10 AM
i have 2611xm voice gateway,
now i using MGCP.
do i use mgcp and h.323 with one voice gateway ?
i think there is not problem if using another route pattern each other.
08-30-2004 06:12 PM
You can use H.323 or MGCP for each voice port. Administer the MGCP ports as usual in CCM. Do NOT administer ports in CCM you will use with H.323. Add an addition gateway in CCM, type H.323, pointing to the gateway and configure dial-peers for the other ports. You are correct in that you will use a different route pattern for those calls.
08-30-2004 06:26 PM
thanks.
i will use h.323 gateway without port , i will use voip.
for mgcp , i will use mgcp.
of course , i will use another route pattern.
but i confused , after i configuring mgcp and h.323,
it does not apply.
08-30-2004 07:10 PM
I haven't seen what version IOS you're running - hopefully a T-train (12.2T or 12.3T).
Anyway, for mgcp add:
mgcp
ccm-manager mgcp
ccm-manager config server xxx.xxx.xxx.xxx. (IP of CCM TFTP server)
ccm-manager config
When you administer the ports in CCM the config should download to the gateway and you should see the ports 'registered' with CallManager. If not troubleshoot mgcp - first step is to make sure the "Domain Name" of the gateway in CCM matches the hostname + domain in the router (ie. 2600.avvid.com).
Now add in your dial-peers for the ports you did NOT administer in CCM -
dial-peer voice xxxx voip
destination-pattern
session-target ipv4:xxx.xxx.xxx.xxx
voice-class codec 1 (build this globally or hard-code here)
voice-class h323 1 (build this globally)
incoming called-number .
dtmf-relay h245-alphanumeric
progress_ind setup enable 3
no vad
dial-peer voice xxxx pots
destination-pattern 9
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port ?/?:?
What do you mean by "does not apply"?
08-30-2004 09:29 PM
thanks about your answer.
router ios version is 12.3(7)T.
now, i know that h.323 gateway does not operate.
strangely , h,323 does not operate.
below my h.323 configutration,
plz,check false.
p dhcp pool e
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
option 150 ip 192.168.0.99
dns-server 210.94.0.73 210.220.163.82
netbios-name-server 210.96.0.73 210.220.163.82
voice-card 1
voice service pots
voice service voip
h323
h245 caps mode restricted
voice class codec 1
codec preference 1 g711ulaw
fax interface-type fax-mail
class-map match-all class1
match access-group 101
policy-map policy1
class class1
bandwidth 3000
random-detect
random-detect precedence 0 32 256 100
translation-rule 1
Rule 0 ^80 0
Rule 1 ^81 1
translation-rule 2
Rule 0 ^90 0
Rule 1 ^91 1
translation-rule 3
Rule 0 ^71 1
Rule 1 ^70 0
Rule 3 ^78 8
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
service-policy output policy1
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id Serome Gatekeeper 47 ipaddr xxx.xxx.xxx.xxx 1719
h323-gateway voip h323-id krisnet1@2004@01:031
h323-gateway voip tech-prefix 8#
h323-gateway voip bind srcaddr 192.168.1.2
ip rtp priority 16384 16383 40
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.0.1 255.255.255.0
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http path flash:
prefix-length 29
ip nat inside source list 1 pool local overload
ip nat inside source static 192.168.0.50 !
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
voice-port 1/0/0
supervisory disconnect dualtone mid-call
cptone KR
timeouts interdigit 2
connection plar opx 122
caller-id enable type 1
voice-port 1/0/1
cptone KR
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 22 pots
destination-pattern 155
fax rate voice
port 1/1/1
dial-peer voice 23 pots
destination-pattern 117
port 1/1/0
dial-peer voice 7777 voip
destination-pattern 1..
session target ipv4:192.168.0.99 ---->CM IP
codec g711ulaw
dial-peer voice 2 pots
preference 7
destination-pattern 8T
translate-outgoing calling 1
port 1/0/0
forward-digits all
dial-peer voice 3 pots
no digit-strip
port 1/0/1
forward-digits all
gateway
alias exec c conf t
alias exec s sh run
alias exec e exit
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password xxxxx
login
