MIBs for MCS server CPU and memory utilization
kim-yin_tay
We have a IP Telephony setup at the customer site, with Call Manager software running on Compaq MCS 7825/35 servers.
Are we able to monitor the CPU utilization and memory utilization of Compaq servers by polling the MIBs via SNMP ?
I search thru' the MIB list on the below mentioned website but was unable to find CPU utilization or memory utilization MIB for the MCS server.
ftp://ftp.cisco.com/pub/mibs/supportlists/callmanager/callmanager-supportlist.html
Anybody could advice on this issue ?
mchin345
Level 6
Level 6
You can successfully monitor cpu utilization and memory utilization in Compaq MCS 7825/35 servers by polling MIBs via Snmp.
MCS supports Real-time and historical application performance monitoring through operating system tools and SNMP. The following document explains the same:
http://www.cisco.com/warp/public/cc/pd/nemnsw/callmn/prodlit/callm_ds.htm
Hope this helps!!!!
Thanks for replying to my query. However, could you point me to the MIB which i should be monitoring ?
The url you pointed out is an introductory document to Call Manager 3.1 and does not elaborate on the MIB details. It just mention that there are MIBs available.
What i needed is the MIB name and instance so that i could use a software like MRTG to poll the particular MIB ?
