Mobile Remote Access Expressway - Inactive Jabber
Andrew M12
Have deployed an Expressway-C on the internal and Expressway-E on the DMZ, followed the config guide here, have checked it through 4-5 times now and satisfied everything is configured correctly
www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-1-1.pdf
CUCM version is 9.1(2)
IM + P version is 9.1(1)
Jabber for Windows is 9.7
Jabber for Iphone/Android is 9.6
All Jabbers connect fine inside the network, when on the outside they reach the Expressway-E ok but then get an error “Cannot locate server. Check your server address. If the problem persists, contact your system administrator. Send problem report”
When checking the problem report I see this output on all failed connections (Iphones and Androids)
05-08 16:22:08.863 32374 32374 I         : INFO [0x40028ffc] [ts/adapters/imp/components/Login.cpp(90)] [imp.service] [OnLoginError] - ****************************************************************
05-08 16:22:08.863 32374 32374 I         : INFO [0x40028ffc] [ts/adapters/imp/components/Login.cpp(91)] [imp.service] [OnLoginError] - OnLoginError: (data=0) LERR_JABBER_UNREACHABLE <14>:
05-08 16:22:08.863 32374 32374 I         : INFO [0x40028ffc] [ts/adapters/imp/components/Login.cpp(92)] [imp.service] [OnLoginError] - ****************************************************************
I looked up LERR_JABBER_UNREACHABLE and found this blog about it being a bug for Jabber over VPN which is the opposite of Mobile Remote Access, however I still tried the workaround for the bug but it didn't help
http://blog.prorouting.com/2013/12/cisco-jabber-on-iphone-through-asa-vpn.html
Checking on the Expressway-C under Status>Unified Communications I do see an error about Inactive Jabber on the Expressway-E so unsure if this is the cause. Could find no info on this error message in the setup guide or on google
(note – the 2 alarms bubble is just about how I haven’t changed the default passwords, no alarms relating to this Inactive Jabber)
Has anyone else seen this problem yet and knows how to resolve it?
55 Replies 55
I said that no firewall because I used NAT 1:1 from Public IP to DMZ IP.
Ok, then if you've followed the blog and guide to the letter and everything is configured as recommended then I would suggest debugging and checking logs of all devices in the path to ensure traffic is flowing or if one of them is blocking/dropping it.
my question is like you:
https://supportforums.cisco.com/discussion/12290906/expressway-core-xcp-server-connection-questionand-c-and-e-connect-okbut-jabber
i can not login form outside.
my toply have connection one switch in test,have no asa
use different DNS for inside and outside
hailin huang
hi,tigrepojke  and   phanletienvinh
i need your help.
task1: expressway core have one not active
XCP Server connection: 192.168.99.13(edge) :Inactive Jabber is not running on remote host, if jabber is running then check password for r2r connection on connect
when i shut lan2 on expressway-edge ,this question is ok
all is active.
but i can not login from outside?
note 2:
now ,on expressway-E i use IPv4 static NAT mode .my expressway is ok
i can login from outside ,but i can not use softphone ?
IPv4 static NAT address is same with  ipv4  lan1 on EDGE,is this questin?
Hello huanghle
Ok so it looks like you resolved your issue with the Inactive Jabber and sign-in problems by disabling Lan 2 and using Static Nat, good.
Your problem now is being unable to use a softphone, is this the Jabber softphone?  If so then do you have the CSF client setup on the CUCM for the Jabber to use?
If you have been using an Iphone or an Android then again have you setup a device for them?
Jabber softphone = phone type Cisco Unified Client Services Framework
Iphone = phone type of Cisco Dual Mode for iPhone
Android  = phone type of Cisco Dual Mode for Android
And so then if you have setup the phones on the CUCM, in the Jabber client check under Help>Show Connection Status and it gives a nice report on how healthy the Jabber is for connections to all servers (softphone, deskphone, voicemail, presence etc)
Jabber for Windows/iphone/android should show an error message if it is having issues with the softphone, it would be useful to know what that is as no doubt it will lead to some answers on a search.
Thank you for your reply
my user login inside can use all IM/JABBER SOFTPHONE  from PC or iphone or jabber
when i use this user login from outside(use expressway core and edge), i can use IM ,but can not use jabber softphone.
my pc jabber login log in the file
my connection error message is:
软电话 - 不健康
状态: 未连接
协议: SIP
原因:连接错误。请确保 [选项] 窗口中 [电话服务] 选项卡下的服务器信息正确无误。如果需要支持,请与系统管理员联系。
地址: 192.168.99.10 (CCMCIP - Expressway)
桌面电话 - 无
状态: 未连接
协议: CTI
地址: 192.168.99.10 (CTI)
在线状态 - 健康
状态: 已连接
地址: expe.camsl.com
协议: XMPP
端口: 5222
Outlook 通讯录 - 健康
状态: 上次连接成功。
协议: MAPI
地址: Outlook
目录 - 健康
状态: 上次连接成功。
地址: 192.168.99.10
协议: UDS (HTTPS)
Unable to see what the Connection Status is as I'm unfamiliar with what looks to be Chinese
I took a quick browse through the logs searching the keyword "error" and it got a lot of hits so you might want to try googling those.
Something else on the Jabber that might point you in the right direction is Help>Show Error Notifications
If it were my system I would be logging into Jabber Windows when connected to the LAN, record the time you do this.  Then logging into Jabber Windows from outside and record that time, then compare the logs to find a discrepancy. Would also be checking the CTI logs on the CUCM system
You might have SIP Profile Issue, do as following and see if it gets resolved:
1. On Unified CM, go to Device > Device Set t ings > SI P Prof ile.
2. Click Copy against the St andard SI P Prof ile.
3. Configure the following fields, leaving everything else as its default value:
Name Standard SIP Profile – for phone devices
Use Fully Qualif ied Domain in SI P
Request s
Allow Present at ion Sharing using
BFCP
4. Click Save.
Select the check box
Select the check box if BFCP (Dual video / presentation sharing) is
required.
from cisco: Cisco Expressway SIP Trunk to Unified CM  Deployment Guide
Andrew M12
In case anyone is following this thread or find it when researching Expressway, this thread is for the Mobile Remote Access part of it
If you are interested in the B2B part then you can find my journey with that over at this thread
https://supportforums.cisco.com/discussion/12282746/cucm-vcs-core-and-edge-b2b-calling
hi,tigrepojke. and all:
question 1: jabber login outside,not use softphone  //OK
my softphone can login from outside through EDGE.
before i have change cucm sip phone port from 5060 to 5062,for my andorid jabber.
if i change back cucm port 5060,my andorid jabber can not use softphone,only use IM.
question 2:jabber outside can not ring
my outside jabber can call inside jabber,but inside jabber call outside jabber,
outside-jabber can not ring,call fail.
have cucm /10.5,expressway core and edge/
expresssay-core-edge-log file
Hello huanghle
Same advice as a month ago. Take logs for a working scenario then compare them against logs from your problem scenarios
