MWI issue
mrugeshpatel_2
CM: 3.3.3es41, Unity: 4.0(3), sometimes MWI comes on when there is no V.M, and sometimes MWI doesn't come on even if there is a message
mp5925@sbc.com
6rmisior
Try running MWI Synchronization "Synchronize Now" on Unity.
Tool Depot----- Switch Integration Tools ---- Telephone Integration Manager
Click on Cisco CallManager then Properties.
Hope this helps.
Robert
6rmisior
Hope this helps.
Robert
Try to resynch the MWI.Go to unity tools depot and under switch intergration go to unity integration monitor and under properties click on "resynch mwi now".I would say it would be better to setup a regular mwi resych may be for every day during the night time.
I hope this helps.
thanks,
Radhika
mrugeshpatel_2
Thanks, everybody for the replies, here is what fixed it, another tech was working on some PBX issue and he had configured some extn's for park range and my MWI extn's happened to be inside that range. Excluded the MWI extn's out of the Park range and everything is functiong normally. Once again thank you for replying to my question
