10-14-2002 01:21 PM - edited 03-12-2019 09:09 PM
Hi everyone;
I'm trying to implement a VG200 (NM-HDV) PRI interface with Nortel Meridian. Running MGCP with IOS 12.2(11)T. Although we are just finding out that this no longer supports network side (Providing clocking) to the PBX? Unfortunately this is a major "ouch" since the PBX cannot be set as network side or to provide clocking. As well, the PBX does not have the load installed to support the NI protocol.
Are there any work arounds that are out there? Or IOS versions on the VG200 that supports this basic feature?
Thanks in advance.
John.
10-14-2002 01:34 PM
Network side emulation of the isdn switch are not supported on primary-5ess, dms-100 or primary-4ess switch types. There is no IOS version that this is supported in either. The only switch type that supports network side is ni/ni2. There is however a work around. There is a hidden command "isdn network" under the d channel, that can enable network type emulation, however when the router is reloaded the configuration will dissapear. The reason this command is not released or supported, is because the resources have not been put into testing this throughly enough to be integrated as a feature in IOS.
However this is just network side emulation of the switch, you can still proivde clocking to the PBX with clock source internal under the T1 controller.
10-15-2002 06:00 AM
Thanks for your help guys. Although, I'm still running into an issue with this, and I'm told that it should be working the way I have it.
The Option 11 is configured for User side, External Clocking, and DMS100.
The VG200 is set for NI2, Internal Clocking, and Network side.
I'm bringing up the D-Channel, although when I place a call, it 'seems' as if the B-Channel is either not being setup, or being setup breifly then torn down immediately. (Phone goes on-hook right away).
The debug from the PBX states:
PRI227 DCH: 15 DATA: 00000004 CALLING #: 1003 NUM PLAN: E164
CALLED #: 8000 NUM LAN: E164
Which shows all good data coming from the D-Channel.
Here's the VG200 config:
version 12.2
no parser cache
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname XXXXX
logging buffered 4096 debugging
no logging console
enable password happy
voice-card 1
ip subnet-zero
isdn switch-type primary-dms100
voice call carrier capacity active
voice rtp send-recv
voice service voip
ccm-manager redundant-host x.x.x.x x.x.x.x
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
controller T1 1/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24 service mgcp
description MacMillan PSTN Facing PRI
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
description Plug into Voice VLAN 110 at Bloorview
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
isdn flip-chan-flag
isdn bind-l3 ccm-manager
no cdp enable
interface Serial1/1:23
no ip address
isdn flip-chan-flag
no cdp enable
ip classless
no ip http server
logging trap debugging
call rsvp-sync
voice-port 1/0:23
voice-port 1/1:23
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
dial-peer voice 1023 pots
application mgcpapp
dial-peer voice 9991023 pots
application mgcpapp
port 1/0:23
dial-peer voice 9991123 pots
application mgcpapp
port 1/1:23
Again, any help is greatly appreciated.
John.
10-14-2002 02:41 PM
Here is a config that has worked in many many locations.
On the IOS gateway:
controller T1 1/0
framing esf
clock source line primary
linecode b8zs
isdn flip-chan-flag
!If on earlier version of IOS (12.1.x) use next
isdn tei-negotiation first-call
On the Nortel Meridian Option X
1) Meridian 81c using NI2 Network side will only process the last 4-5 digits of any number, so tandeming to the PSTN is not possible (in fact, if the last 4-5 digits of the number sent out match a PBX phone extension that phone will ring).
2) Set Meridian PRI to S100 Network side if software allows. Successful integrations seem to be running version 22 or later on the Meridian.
3) Must set "S100" on the trunk group (RDB) and on the D-channel config. They can then set the PBX for network side.
4) Set VG200 for DMS100 User side. Caller name should work with IOS 12.2(5)
5) Make sure PBX tech downloads MSDL channel if D channel does not come up.
6) PBX tech will also have to make sure correct parameters are set to pass calls from his PRI to CallManager to PRI on PSTN (NCOS, TGAR, others)
Here is some pertinent config info from a Meridian PBX that is
working with the above PRI config:
On the D-Channel:
CTYP MSDL
GRP 1
DNUM 15
PORT 2
USR PRI
DCHL 25
OTBF 128
PARM RS422 DTE
CLOK EXT
IFC S100
SIDE NET
CNEG 1
RLS ID **
RCAP ND2
On a trunk (ds0)
TYPE TIE
CDEN SD
CUST 0
TRK PRI
PDCA 1
PCML MU
NCOS 2 <<< Depends on permissions in switch
RTMB 79 1
B-CHANNEL SIGNALING
TGAR 1 <<< Routing code. Could be different.
AST NO
IAPG 0
CLS CTD DTN and so on <<< Maybe should be UNR not CTD?
TKID
FCAR NO
On the trunk route:
TKTP TIE
ESN NO
CNVT NO
SAT NO
RCLS EXT
DTRK YES
DGTP PRI
ISDN YES
MODE PRA
IFC S100
SBN 0
PNI 00000
NCNA YES
NCRD NO <<<< Depends whether NO or YES
CHTY BCH
CTYP UKWN
INAC NO
ISAR NO
DARC NO
BCOT 0
DSEL 3VCE <<< also works as VOD
PTYP PRI
AUTO NO
DNIS NO
ICOG IAO
SRCH RRB <<< Can be set to LIN (linear hunt)
TRMB YES
STEP
ACOD 7979
TCPP NO
TARG 01
CLEN 1
BILN NO
OABS
INST
IDC NO
DCNO 0 *
NDNO 0
DEXT NO
ANTK
SIGO STD
ICIS YES
and so on ......
