i do not believe 1GB works but 10G should work.( again what port you are using ?)
check optic compatibility :
https://tmgmatrix.cisco.com/
when you plug what is the logs show ?
post output
show run interface eth x/x
show interface eth x/x trans
show interface eth x/x capa
