No Voice-Port in Module NIM-1CE1T1-PRI
silvakizir
Hi guys.
Recently I had a Problem when trying to configure a VWIC card NIM-1CE1T1-PRI and because I managed to do so I want to share it with you.
I have a Router which has a 4th generation card in Slot 0/1/0 where I was able to configure the Controller E1 0/1/0 and the Interface Serial 0/1/0:15
Unfortunately when I tried to go to Voice-port 0/1/0:15 there was no such thing.
Bellow I have the commands I used to "open" the ability to configure the Voice-port 0/1/0:15
controller E1 0/1/0
pri-group timeslots 1-31 voice-dsp
This Card needed the above command in bold to give me the option to configure the Voice-port since it has the DSPs in it and not on the motherboard.
Please Rate if Useful.
Amrous_mohamed
hi ,
 you should add this CLI
voice-card 0/1/0
dsp services dspfarm
no watchdog
