09-07-2006 04:15 PM - edited 03-13-2019 02:54 PM
i have a remote site(SRST)2821 connected to my main callmanager , i can call all the extensions internally without any problem, but when i transfred an incomming call from from my pri gateways to any of the remote extensions, they can't here anything but the caller has the voice (oneway situation)
any help would be appreciated
09-07-2006 04:40 PM
there are a few reasons that one way audio can be created.
for starters, please see the following link for 'one-way-audio' troubleshooting:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
09-07-2006 05:34 PM
thanks for reply
i check everything in troubleshooting
but the problem is when i call remote extensions i have no problem and also when i transfer calls that came from my analog gateway (FXO) still no problem, problem happend when i transfer calls that came to my PRI Lines , and my pri gateway configuration, like CSS and ... is the same as my analog gateway.
09-08-2006 06:22 AM
one more thing my pri lines are comming from
a cat 6509 switch with x6608 blade that has catos,how can i check "ip routing" command on catos?
