10-31-2001 12:57 PM - edited 03-12-2019 01:07 PM
With ccm 3.1 and vg200 with 1 vic-2bri configured as H323 gateway (no alternatives) incoming calls work great. Outgoing calls last only 9 seconds. Aftern that vg200 drops the call.
Vic is connected to an ISDN NT box of provider.
Disconnect cause 0x29 (Temporary failure)
Any ideas?
I thing it might have to do with frequencies
10-31-2001 06:32 PM
Can you enable debug isdn q931 when you make an outbound call and post the output here? Also, which IOS version is being used on the VG200, and can you post the configuration also?
10-31-2001 11:50 PM
This is the sh ver
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
000094 0X000BA600 C2600 Single Fast Ethernet
000065 0X00013500 Four port Voice PM
0X000F34A8 public buffer pools
0X00211000 public particle pools
TOTAL: 0X003D1FA8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 12 percent iomem. [4Mb/32Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) VG200 Software (VG200-I6S-M), Version 12.1(5)XM4, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc2)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 02-Jul-01 21:58 by liha
Image text-base: 0x80008088, data-base: 0x80828C90
cisco VG200 (MPC860) processor (revision 0x102) with 28672K/4096K bytes of memor
y.
Processor board ID JAB05340M2L (0)
M860 processor: part number 0, mask 49
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 ISDN Basic Rate interface(s)
4 Voice TE BRI interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
Here is the config
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname vg
logging rate-limit console 10 except errors
enable password cisco
ip subnet-zero
no ip finger
no ip domain-lookup
no mgcp timer receive-rtcp
call rsvp-sync
isdn switch-type basic-net3
isdn voice-call-failure 0
interface FastEthernet0/0
ip address 192.168.6.103 255.255.255.0
duplex auto
speed auto
interface BRI1/0
no ip address
isdn incoming-voice voice
interface BRI1/1
no ip address
ip classless
no ip http server
voice-port 1/0/0
echo-cancel coverage 16
compand-type a-law
cptone GR
connection plar 101
description ISDN line 5193790
bearer-cap Speech
voice-port 1/0/1
compand-type a-law
cptone GR
dial-peer voice 100 pots
destination-pattern T
direct-inward-dial
port 1/0/0
prefix 0
dial-peer voice 3000 voip
destination-pattern 101
session target ipv4:192.168.6.100
codec g711alaw
gateway
line con 0
transport input none
line aux 0
line vty 0 4
password cisco
login
end
Soon I'post the debug isdn q931...
Debug voice ccapi inout shows disconnect cause 0x29
and debug cch323 h225 shows that vg200 places the call from h323_active to idle.
12-21-2001 12:10 AM
The ios was finally the problem.
The one that comes with vg200 (12.1.5xm) worked in 2 locations. At the exact location where the roll out was implemented never worked (dropped the outgoing calls after 9 secs, as well as crashed the vg200 when we were calling a specific cellular company!!)
I tryied also 12.5.1xm4, 12.1.5T9, 12.2.6 and the problem was not solved. We contact the local PTT
and these guys checked in real time the disconnection reasons (friends from the past)
So when PTT said that the call was rejected from our side I reinstalled the ccm. No good.
Finaly, beign desperate I downloaded 12.2.2T and ...
MAGIC happens because of christmas I suppose.
One Alitalias small branch office in Athens Greece is live with IP Telephony since 18 Dec 2001.
Thanks anyway.
P.S. Dam those IOS. It's not the 1st time I get in trouble with it.
