09-16-2004 10:01 PM - edited 03-13-2019 06:23 AM
I have just connected a ccme in sweden and all outging calls get fast busy. Incoming work fine.
Can someone have a qick look at the debug q931 and sh voice port below. I think its the service provider but want to make sure. (the call below is to london in uk)
Router#
Sep 16 17:44:26: ISDN Se0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0858710830
Sep 16 17:44:26: ISDN Se0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 0
Sep 16 17:44:26: ISDN Se0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0010
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '0858710830'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0'
Sep 16 17:44:26: ISDN Se0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8010
Cause i = 0x82D21803A9839E - Identified channel does not exist
Display i = 'IDENTIFIED CHANNEL DOES NOT EXIST'
09-16-2004 10:10 PM
Looking at the cause code here is what it means
The receiving equipment is requested to use a channel that is not activated on the interface for calls.
This cause indicates that the equipment sending this cause has received a request to use a channel not activated on the interface for a call. For example, if a user has subscribed to those channels on a primary rate interface numbered from 1 to 12 and the user equipment or the network attempts to assign a call to channels 13 through 23, this cause is generated.
The following link will be useful
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml#topic1
Can you please paste the router configs.
Radhika
09-17-2004 12:14 AM
Hi Radhika
just before you replied to my question,the telecom provider called me to say channels 17-31 were not programed in the CO. So your information was spot on, thanks for the reply.Its working fine now.
regards
colin goona
