Outside calls do not hear Voicemail Greetings
bmcdonald
Unity 3.1(2) with CallManager 3.1(2c)<br>Gateway is a Catalyst 4000 with an AGM card running 12.1(5)yf3<br><br>Outside calls routed to Unity cannot hear the VM Greetings or prompts. However, if the person speaks Unity takes a message. We have checked that the codex are all 711.<br><br>
Anil Verma
Level 5
Level 5
See if this helps -
http://www.cisco.com/warp/customer/788/AVVID/1way_audio.html
Anil Verma
Cisco Systems
anilve@cisco.com
There are a bunch of things this could be. Can you post your config please? Do you have 2 NICs enabled on the machine or 2 IP address assigned to one interface on the Unity? Does this only happen for external calls? Does this ever happen on calls to IP phones?
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
kechambe@cisco.com
I am running into the same problem. Internal calls (ip phone to unity) work fine. However, when you call in from the pstn, you cannot hear unity, but can record. We hav only one ic set up on the unity box. We are using g711 as the protocol.
