PerfLib "DNS" Errors on system running Unity
jasonhumes
I just reviewed my event log on my unity system and am seeing a huge number of perflib errors and they seem to be related to DNS. What could be the issue here and how could I clean these up. Thanks
5 Replies 5
lindborg
can you actually post the full content of one of these errors for us to look at?
Here are the messages relating to this problem. Thanks for the help!!!
Registration of the DNS record '_gc._tcp.Default-First-Site-Name._sites.acsip.on.ca. 600 IN SRV 0 100 3268 ICS-436af0a2f7e.acsip.on.ca.' failed with the following error:
DNS operation refused.
The Open Procedure for service "DNS" in DLL "C:\W2KS\System32\dnsperf.dll" failed. Performance data for this service will not be available. Status code returned is data DWORD 0.
These were two different messages, both errors, and I thought that they may be related. Thanks again
actually, I was gunning for the full event log entry information - the easiest way to do this is to use the "copy" button on the event log viewer which will include the event source, event Id and all that good stuff as well as the text of the error itself - this way we can look things up in online databases - makes it easier to find possible solutions that way.
Hello again,
Here are the actual events, as copied from Event Viewer. Thanks again.
Event Type: Error
Event Source: Perflib
Event Category: None
Event ID: 1008
Date: 5/2/2003
Time: 10:59:46 AM
User: N/A
Computer: ICS-436AF0A2F7E
Description:
Data:
0000: 02 00 00 00 ....
Event Type: Error
Event ID: 1010
Date: 5/2/2003
Time: 11:00:06 AM
User: N/A
Description:
The Collect Procedure for the "PSched" service in DLL "C:\W2KS\System32\pschdprf.dll" generated an exception or returned an invalid status. Performance data returned by counter DLL will be not be returned in Perf Data Block. Exception or status code returned is data DWORD 0.
Data:
0000: 3d 01 00 00 =...
Event Type: Error
Event Source: NETLOGON
Event ID: 5774
Date: 5/2/2003
Time: 10:19:48 AM
User: N/A
Description:
Registration of the DNS record '_kpasswd._tcp.acsip.on.ca. 600 IN SRV 0 100 464 ICS-436af0a2f7e.acsip.on.ca.' failed with the following error:
Data:
0000: 2d 23 00 00 -#..
Thanks again.
Hi !
You're first error message is associated with the fact .. that the DNS Server configure for the Network Interface on the server is not configure to "Allow Dynamic Update
Ensure that :
- The DNS Parameter for the NIC is set to blank (this will set the DNS to : 127.0.0.1), or the local IP Address of the UNITY .
- Ensure that the DNS Service is started on UNITY
The Second one .. if a reference bug on MS Knowledge Base
Look for :
Microsoft Knowledge Base Article - 304541
System Monitor Is Missing in the DNS Counters and Event ID 3009 Is Logged
Hope this will help !
MARTIN
