Phone Load Compatibility
jihealis
Does anyone know of a document that shows what phone loads are compatible with which version of CM?
I just want to make sure that when I upgrade to 4.1 that I cause the forced reset of all my phones just to get the new load.
It is still listed on CCO.
cmterm-7940-7960-sccp.5-0-6.exe
IP Phone load for 7940/7960 IP Phone - Compatible CCM Version: 3.3, 3.2 & 3.1
Image was posted on 08-JUL-2004. It is listed for 7910, 7940, and 7960.
Srikanth
sgelli
Level 4
Level 4
The phone load download page shows which version of CallManager the phone load is compatible with.
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser
The following URL shows the default phone load that comes with the CallManager.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm#RANGE!A33
Hope that answers your question.
Srikanth
Thanks! It gets me close enough, I think.
Right now I have P003-5-0-6, which isn't listed. So I suspect that it's been pulled for some reason I can't find yet. The next earlier version that is listed is not compatible, so it looks like I will be stuck with resetting 2000 phones at once. Ugh!
Srikanth
