Phone rings 3 times before going to voicemail
mmonteiro11
Can I decide how many rings before the caller goes to voicemail? If this a phone setting? Also, am I able to disable call waiting for my phone?
Jaime Valencia
yes, this can be changed thru the service parameters for all phones or per line at the line config page. a ring means about 4 seconds so just do the math.
if you do not want call waiting change the busy trigger to 1 on the line.
java
if this helps, please rate
java
Rob Huffman
Hi Michael,
If you are using Callmanager (later than CCM 4.1) you can change the number of rings before FNA to voicemail using this setting
(under>Device>Phone>Directory Number Configuration)
No Answer Ring Duration (seconds)
If you want to change this "system wide" let me know as this can be adjusted as well.
To disable Call Waiting for the phone change the Busy Trigger to 1
Hope this helps!
Rob
So this cannot be set using the IP phone? It sounds like it has to be set using some software called CallManager. If so, I'll have to talk to our IT guy.
ohhh your question was how to set it on the ip phone???? no way to do that, has to be done on callmanager
java
java
