10-06-2005 10:07 AM - edited 03-13-2019 10:46 AM
call answered on one phone, when it is transfered to another extension, the phone that its being transfered to will show on the display the transfer , but will not ring. check volume setting on phone and reset the phone.
10-13-2005 05:55 AM
Which CME version are you using? You, can try to change the phone load and see if it resolves the problem
10-13-2005 07:09 AM
version 3.3...
i have changed the phone load and that has resolved the problem.
