PRI Error Logging on Catalyst 6000 Blade
benhanson
Anyone familiar with locating PRI errors on a Catalyst 6000? The only command I can find is show port voice fdl which seems to give some error information. I'd like to be able to monitor any circuit disconnects. I've set up syslog as well, though I'm not sure what an appropriate facility and severity level would be.
Not applicable
From Call Manager you can web into the actual port that is terminating voice and see stats disconnects and so on. Also you can run the 'Dick Tracy' tool on the Call Manager that the 6608 port is registered to and receive great detail as to what is happening.
Good luck and let me know if you have any questions.
