Proble to connect Cisco ATA 186
tanc08
After I purchased Cisco ATA 186, I connected to Cisco Call Manager 3.3.4, and it worked. I don't know the version of firmware at that time.
Recently, I used my ATA 186 to test PC to Phone call. It is H323 gatekeeper. So, I upgraded the latest H323 3.01 firmware to my ATA 186. At this point, Cisco Call Manager did not get involved.
Today, I used this H323, 3.01 version of SCCP, SIP and MGCP tried to reconnect to the call manager, and it failed. It is like ATA 186 and call manager does not know each other.
How do I fix it ? Should I use the default firmware that came with the device ? Can you tell me what is the default firmware ?
Product ID is ATA186-I1-A.
5 Replies 5
ebreniz
Level 6
Level 6
the document below provides information about configuring Cisco CallManager to interoperate with the Cisco Analog Telephone Adapter (ATA) 186 using Skinny Client Control Protocol (SCCP) also known as "Skinny".
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800a892f.shtml
You are right. The default is SCCP.
johnquitete
sip cisco ata 186
sip cisco ata 186
johnquitete
cisco ata 186
