Problem with a requested circuit/channel not available code 44
samaelsaenz
Hi all,
This is my fisrt topic, can anybody knows whats wrong with my conf, cause, when i debug isdn,
Jun 26 00:18:59.823: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (172.19.38.14)
vg01#
Jun 26 00:19:29.878: ISDN Se0/2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 3898
Jun 26 00:19:29.879: ISDN Se0/2/1:15 Q931: Sending SETUP callref = 0x0089 callID = 0x8004 switch = primary-net5 interface = User
Jun 26 00:19:29.879: ISDN Se0/2/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0089
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '3898'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '26620000'
Jun 26 00:19:30.020: ISDN Se0/2/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8089
Cause i = 0x82AC - Requested circuit/channel not available
Please help.
Have you talked to your Telco ? The disconnect is being generated by them -
0x82AC >> 82 is an upstream switch or device in the PSTN network
Also, you are sending an internal extension out to your Telco ? Is that right ? Change it to a permitted DID.
10 Replies 10
Ratheesh Kumar
Hi there
Are you using full PRI or a fractional one. You might need to check with your Telco also.
I just did a search and found the same exact issue got resolved by Unchecking "Inhibit restarts at PRI initialization" on the CCM gateway configuration page. Reset the GW after the change
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
Thanks for your answer, is a full PRI, but in my ver of CUCM, that check box, doesnt exist :(
This is the config if you want to take a look.
controller E1 0/1/0
framing no-crc4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
controller E1 0/2/0
framing no-crc4
pri-group timeslots 1-16
controller E1 0/2/1
framing no-crc4
pri-group timeslots 1-31
interface GigabitEthernet0/0/0
ip address 172.18.0.6 255.255.255.0
negotiation auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.18.0.6
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/2/0
interface Serial0/2/0:15
description E1_FOL
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
no cdp enable
interface Serial0/2/1:15
description E1_Columbus
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.18.0.1
ip ssh version 2
control-plane
voice-port 0/1/0:0
disc_pi_off
bearer-cap Speech
voice-port 0/2/0:15
voice-port 0/2/1:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm 172.19.7.62 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 100
bind interface GigabitEthernet0/0/0
associate ccm 1 priority 1
associate profile 15 register TC-HN-SPS
associate profile 20 register CB-HN-SPS
dspfarm profile 15 transcode
description transcoding
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 9
associate application SCCP
dspfarm profile 20 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 5
dspfarm profile 25 mtp
codec g711ulaw
shutdown
dial-peer voice 1 pots
description Emer
preference 1
destination-pattern 9911
incoming called-number ....
direct-inward-dial
port 0/1/0:0
dial-peer voice 11 pots
description Emergencias_Al
preference 2
direct-inward-dial
port 0/2/1:15
dial-peer voice 2 pots
description Emergencias H
preference 1
destination-pattern 919.
direct-inward-dial
port 0/1/0:0
dial-peer voice 22 pots
preference 2
direct-inward-dial
port 0/2/1:15
dial-peer voice 3 pots
description Nacionales
preference 1
destination-pattern 92.......
progress_ind setup enable 3
direct-inward-dial
port 0/1/0:0
forward-digits 8
dial-peer voice 33 pots
description Nacionales-Cl
preference 2
destination-pattern 9[2,3,8,9].......
incoming called-number ........
direct-inward-dial
port 0/2/1:15
dial-peer voice 4 pots
description Extensiones_FOL
destination-pattern 88[1,2,4][1,2,8]....
direct-inward-dial
port 0/2/0:15
dial-peer voice 5 pots
tone ringback alert-no-PI
description Extensiones_FOL2
destination-pattern 8811....
direct-inward-dial
port 0/2/0:15
dial-peer voice 101 voip
description Salida_Es
preference 1
destination-pattern 31T
session target ipv4:172.19.7.62
voice-class codec 1
dtmf-relay rtp-nte digit-drop h245-signal h245-alphanumeric
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 102 voip
description Int
preference 1
destination-pattern 3011T
voice-class codec 1
dial-peer voice 200 voip
description INBOUND CALLS FROM VOIP
incoming called-number .T
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 6 pots
direct-inward-dial
dial-peer voice 103 voip
description Internos
preference 1
destination-pattern 00..
voice-class codec 1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
line con 0
privilege level 15
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
login authentication local
transport input ssh
network-clock synchronization automatic
ntp server 172.19.0.1
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Can you try changing the isdn bchan-number-order ascending to descending and see that helps
Hope this helps
Cheers
Rath!
 Thanks Ratheesh,
Yes I did and still have the same error :(
Thanks Nipun, i will try this, i hope this solve this problem.
Seems the error still show, same error, i do not know what more to do ATM,
Some suggestion?
Did you contact your Telco like I highlighted earlier ?
Hi and thanks a lot for your anwers, we talk to Telco team and yes, some missconfig, now it works.
Thanks a lot.
what was the misconfig ?
