problem with ISDN
johnsalazar
I am setting a as5300 with one excel switch, and this isn't working.
I saw :
23:17:00: ISDN Se3:23: RM returned call_type 1 resource type 0 response 2
23:17:00: ISDN Se3:23: INCOMING CALL: VOICE ERROR: Requested circuit/channel not available(0x2C): bchan 0, call id F
I am using the follow setting : ATT-4ess, ESF, B8ZS.
Some body, could help me
thanks.
Chester Rieman
Use the show isdn service command to verify that Bchannel 0 is ready for a call. Also run debug isdn q931 and make sure the bearercap and channelID are correct and the router can do the cpabilities asked for in the call setup.
Hi Crieman,
This is my setting:
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(2)XA5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
Voice Feature Card in Slot 1:
VCware Version : 9.08a
ROM Monitor Version: 1.3
DSPware Version : 3.6.6aL
Technology : C549
----------------------------ooooooooooooo---------
ISDN Se3:23, Channel [1-24]
Configured Isdn Interface (dsl) 3
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
Service State (0=Inservice 1=Maint 2=Outofservice)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2
-----------------------000000--------------
controller T1 3
framing esf
clock source line secondary 3
linecode b8zs
pri-group timeslots 1-24
-------------------------0000-------------------
interface Serial3:23
no ip address
isdn switch-type primary-4ess
isdn incoming-voice modem
no cdp enable
-----------------------00000---------
This is log of one call:
23:17:00: ISDN Se3:23: RX <- SETUP pd = 8 callref = 0x000A
23:17:00: Bearer Capability i = 0x9090A2
23:17:00: Channel ID i = 0xA98381
23:17:00: Calling Party Number i = 'A', 0x80, '2131231312', Plan:ISDN,
ype:Subscriber(local)
23:17:00: Called Party Number i = 0xC1, '225763360340', Plan:ISDN, Type
Subscriber(local)
23:17:00: ISDN Se3:23: Incoming call id = 0x000F, dsl 3
23:17:00: ISDN Se3:23: NegotiateBchan: bchan 1 intid 0 serv_st 0 chan_st 0 call
d 0x0000 ev 0x90 n/w? 0
23:17:00: Negotiated int_id 0 bchan 0 cr=0x800A callid=0x000F lo_chan 1 final i
t_id/bchan 0/1 cause 0x0
23:17:00: ISDN Se3:23: LIF_EVENT: ces/callid 1/0xF CALL_INCOMING
23:17:00: ISDN Se3:23: CALL_INCOMING dsl 3 bchan 0
23:17:00: ISDN Se3:23: CALL_INCOMING: call type is VOICE ULAW, bchan = 0
23:17:00: ISDN Se3:23: Event: Received a VOICE call from 2131231312 on B0 at 6
Kb/s
23:17:00: ISDN Se3:23: process_disconnect(): call id 0xF, call type is VOICE, b
idb 0x625848A4, ces 1, cause Requested circuit/channel not available(0x2C)
23:17:00: ISDN Se3:23: TX -> CALL_PROC pd = 8 callref = 0x800A
23:17:00: ISDN Se3:23: TX -> DISCONNECT pd = 8 callref = 0x800A
23:17:00: Cause i = 0x80AC - Requested circuit/channel not available
23:17:00: ISDN Se3:23: RX <- RELEASE pd = 8 callref = 0x000A
23:17:00: ISDN Se3:23: CCPRI_ReleaseCall(): bchan 1, call id 0xF, call type VOI
E
23:17:00: CCPRI_ReleaseChan released b_dsl 3 B_Chan 1
23:17:00: ISDN Se3:23: LIF_EVENT: ces/callid 1/0xF CALL_CLEARED
23:17:00: ISDN Se3:23: received CALL_CLEARED call_id 0xF
23:17:00: no resend setup, no redial
23:17:00: ISDN Se3:23: TX -> RELEASE_COMP pd = 8 callref = 0x800A
*Aug 20 20:01:14: %SYS-5-CONFIG_I: Configured from console by vty1 (64.251.19.7
