08-26-2002 04:08 PM - edited 03-12-2019 08:31 PM
I have a cisco 3640, in the slo 3 a NM-HDV-1E1-12 with a VWIC 1MFT-E1 and a don't know how to configure this network modules
Whit the command sh diag 3 the result is the next
Slot 3:
High Density Voice Port adapter
Port adapter is disabled
Port adapter insertion time unknown
WIC Slot 0:
E1 (1 port) WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 28184565 Part number 800-04475-03
Test history 0x0 RMA number 00-00-00
Connector type PCI
08-26-2002 04:23 PM
What is the image name of the IOS on the router? Router's IOS needs a plus feature set for this NM to be enabled.
More info at the following links:
http://www.cisco.com/warp/public/788/products/vwicmf_e1.html
http://www.cisco.com/warp/public/788/products/hdv_netmod.html
Hope this helps
08-26-2002 04:29 PM
flash:c3640-is-mz.5.bin ----DOS IMAGE NAME is aaa1203----
IOS (tm) 3600 Software (C3640-IS-M), Version 12.1(5a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 16-Nov-00 20:53 by cmong
Image text-base: 0x60008940, data-base: 0x60E60000
08-26-2002 04:52 PM
Router will need 12.1(2)T at minimum to support this card. Try loading 12.1(5)T9 and see if this helps.
08-26-2002 04:54 PM
Hi!,
What you have is E1 port that can be use to connect to the PSTN or PABX which has E1 port also. You can configure that E1 port as E1 R2. Aside from configuring the E1 port, you need also to know how to configure VoIP using E1 so that you can use your router as your voice gateway.
Aside from your 3640, what other Cisco component do you have? Do you have MCS, IP Phone and other voice gateways? At this point, I'm still not sure the system that you are going to implement. If possible, can you described the system that you are going to implement. From there, I can give you some possible configurations in your 3640 router.
Sherwin
