07-19-2004 01:43 AM - edited 03-13-2019 05:40 AM
I have a problem with a VIC2-2BRI-NT/TE.I can receive
incoming calls but I can´t make outcoming calls.Only
can outcoming calls in a few seconds next that receive a incoming call or resetting the interface.
I know the bug of this cards but this is my configuration.
interface BRI0/1
no ip address
no ip route-cache
isdn switch-type basic-net3
isdn tei-negotiation preserve
isdn incoming-voice voice
isdn static-tei 0
sh version
Cisco IOS Software, C1700 Software (C1700-SV8Y7-M), Version 12.3(8)T, RELEASE SOFTWARE (fc
2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Thu 13-May-04 14:12 by eaarmas
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
lmicme uptime is 3 days, 1 hour, 9 minutes
System returned to ROM by reload
System image file is "flash:c1700-sv8y7-mz.123-8.T.bin"
Cisco 1760 (MPC860P) processor (revision 0x500) with 115006K/16066K bytes of memory.
Processor board ID FOC081729SP (40664178), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
2 ISDN Basic Rate interfaces
4 Voice NT or TE BRI interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
sh isdn status
ISDN BRI0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Thanks for your help
07-26-2004 08:52 AM
Are you able to hear the ringback tone when you try to make outgoing calls?? Is the gateway directly connected to the telco or you have it connected to the PBX. The problem could be on the PBX too?? You can use the following flowchart to proceed in a proper troubleshooting way,
ISDN BRI Troubleshooting Flowchart
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094bb8.shtml
Troubleshooting BRI Call Failures over Long Distance Carriers
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a00800c7d61.shtml
