03-25-2011 10:44 AM - edited 03-13-2019 07:22 PM
03-25-2011 01:08 PM
David,
This system is typically related to either
two things:
* License expiration
Check the license file via Notepad to see if there is an expiration date and
if the license has expired.
* Misconfiguration of the HOST settings in the MXE Web UI Administration section.
Verify that the configuration for the defined HOST is correct.
If it is a license issue, you may need to open a case with the TAC to get a new
license file.
I hope this helps!
T.
03-31-2011 06:22 AM
had also a problem with host-Settings!!
Look at
"ecs.host" setting in web.config is mis-configured. | |
Symptom: maybe this will help! Bernhard |
