Problems with MXE
CTSSMERCAV
Yesterday I logged into one of our MXE 3500 and was greated with the following error.
Unable to communicate with the ECS on [localhost:3501]
To my knowledge nothing has been done to the server as I was the last person that it shows logged in and I did not make any changes.  Does anyone have any suggestions or should I escalate this to the TAC?
David
Tomas de Leon
David,
This system is typically related to either
two things:
* License expiration
  Check the license file via Notepad to see if there is an expiration date and
   if the license has expired.
* Misconfiguration of the HOST settings in the MXE Web UI Administration section.
  Verify that the configuration for the defined HOST is correct.
If it is a license issue, you may need to open a case with the TAC to get a new
license file.
I hope this helps!
T.
had also a problem with host-Settings!!
Look at
CSCtn03766            Bug Details
"ecs.host" setting in web.config is mis-configured.
Symptom:
In SnS / MXE integration scenario, SnS can't submit job to MXE with the following error messages:
Unable to communicate with the ECS on  [localhost5:3501]
Anystream.AgilityAPI.ECS.Submit(:0)
Exception:
System.Net.Sockets.SocketException:  No such host is known
at  System.Net.Sockets.TcpClient..ctor(String hostname, Int32  port)
at Anystream.AgilityAPI.ECS.Submit(String command,  Boolean hasResponse)
REST API  Exception
Anystream.RestAPI.RestPage.WriteExceptionResponse(:0)
Exception:
System.Exception:   Unable to communicate with the ECS on [localhost5:3501] --->   System.Net.Sockets.SocketException: No such host is known
--- End of inner exception stack trace  ---
at  Anystream.AgilityAPI.ECS.GetLicenseList()
at  Anystream.RestAPI.Licenses.OnPageLoad()
at  Anystream.RestAPI.RestPage.Page_Load(Object sender, EventArgs  e)
Conditions:
the "ecs.host" setting in web.config file is set to "localhost5", the proper setting should be "localhost".
maybe this will help!
Bernhard
