QoS per udp port on an interface
  Is it possible to configure a CISCO 3560 switch for QoS where we can apply per udp port policies with different Token Bucket rates and burst sizes? If so, how?
Jonathan Schulenberg
Write access lists that match the particular UDP port(s) you want, assign each ACL to a different class, and then assign each class on the policy map with a different policer. Note that you may not be able to do this if the switch has a layer-two only license (i.e. LAN base/lite).
