06-27-2001 07:52 PM - edited 03-12-2019 11:50 AM
Hi.
Errors(?):
In the section,
"Configuring Layer 3 Access Lists for VoIP Control Traffic Classification"
of "AVVID QoS Design Guide",
http://www.cisco.com/univercd/cc/td/doc/product/voice/ip_tele/avvidqos/index.htm
They instruct to use the acl "ACL_IP-PHONES" to configure Layer 3 access lists
for VoIP Control traffic classification.
The acl is supposed to be created in previous
"Marking Control and Management Traffic" section,
and they next show the content as below:
"cat6k-distrib> (enable) set port qos 1/2,3/2 vlan-based
cat6k-distrib> (enable) set qos acl map ACL_IP-PHONES 111
cat6k-distrib> (enable) sh qos acl map run ACL_IP-PHONES
ACL name Type Vlans
ACL_IP-PHONES IP 110,111,112
ACL name Type Ports
ACL_IP-PHONES IP
cat6k-distrib> (enable) sh qos acl info run ACL_IP-PHONES
set qos acl IP ACL_IP-PHONES
1. dscp 26 tcp any any range 2000 2002
2. dscp 26 tcp any any eq 1720
3. dscp 26 tcp any any range 11000 11999
4. dscp 26 udp any any eq 2427
5. trust-cos any "
Should the acl to use here be "ACL_VOIP_CONTROL",
which is made at the same section, not "ACL_IP-PHONES"?
First of all the "ACL_IP-PHONES" should not be like this,
if it is created as shown in the
"Marking Control and Management Traffic" section.
Question:
We are planning to connect as below.
IP Phone --- 3524XL-PWR --- 3508 --- 6500
According to this guide and 3524's reference,
both FastEthernet and GbE interface's out queue
use classification as below and are not user configurable.
Queue # Queue Admission CoS Value
1 0-3
2 4-7
My question is, by default, all control traffic is marked
as Cos & Tos=3 at their source (CCM & IP Phone) and
with above queing strategy, it would not be prioritized.
This does not match the way it is processed
in the Cat6k as explained in the
"Marking Control and Management Traffic" section in the guide.
Since control traffic's priority seems to be configurable from
CCM with the parameters like 'IpTosCm2Dvce',
should I change this from default 3 to 4 so that they
are queued in high priority or is this a mishap to bear
when we use 35XXs as access layer?
TIA
07-09-2001 02:42 PM
Id suggest having your Cisco SE look at and validate your design.
07-09-2001 11:37 PM
Thank you for your reply.
We can't hardly be in touch
with savvy SEs in our region.
That's why I posted here.
07-18-2001 12:25 PM
I would suggest emailing the author of the design guide. His name is Todd Truitt.
