11-26-2001 10:11 AM - edited 03-12-2019 01:30 PM
Is this available? How do I load in a "demo" version to show the folks here how much better it is over the current TTS engine?<br><br>
11-26-2001 11:36 AM
RealSpeak is loaded by default with the demo system. There is no way to jump between RealSpeak to TTS3000 easily and it is not possible at all without a key with TTS3000 set.
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
kechambe@cisco.com
11-27-2001 12:09 AM
So is TTS3000 the engine that sounds good or is it RealSpeak that sounds good? When you purchase Unity UM what engine does it come with?
Is there a key to demo the engine that sounds good, or is the demo for the engine that sounds good part of the standard unity demo system? Where do I find product information on the engine that sounds good? (I know, thats a nontech question, but maybe someone here knows...)
11-27-2001 12:09 AM
The RealSpeak engine is considered to have more realistic audio quality. TTS3000 sounds more like a robot. TTS3000 is the default TTS engine that ships with Unity, RealSpeak has a more expensive license and is a bit more resource-intensive.
Scott Morgan
Cisco Systems TAC
11-27-2001 12:09 AM
Also, RealSpeak is the TTS engine used in Demo mode
-Dustin
