Remote Controls for Tandberg and Cisco
Scott Nieto
I have two old Tandberg VTC remote controls that are beginning to malfunction. Are they covered under the Cisco Army Jela contract?
2ea. Tandberg TRC-4 Remote Control
Can I have these items repaired/replaced?
I also have a newer Cisco remote which has failed;
1ea. Cisco Tandberg TRC V  800-34911-01
Can I have this item repaired/replaced?
I would also like to purchase one additional newer remote;
Can I purchase this item directly from Cisco?
5 Replies 5
Jaime Valencia
You probably want to reach out to your SE/AM, or local Cisco representative to discuss this.
java
if this helps, please rate
Are the items covered under the Cisco Army Jela contract?
As Jaime mentioned, you should contact your Account Manager regarding your questions.  However, in order to get replacements for defective or failed hardware, the endpoints that the remotes shipped with needs to have an active support contract, lookup the endpoint serial number using the Device Coverage Checker.  If you want to purchase spare remotes, the part number is CTS-RMT-TRC5.
Thank you. I don't have an account manager. Thanks for the link to the coverage checker.
Does the TRC5 control both Tandberg and Cisco codecs?
The TRC5 remote is comparable with both TANDBERG and Cisco endpoints. Some older endpoints use an earlier model of the TRC remote, the only difference is some key shortcuts might be different from model to model.
