Reuse TRC6 Remote Control
Translator
Community Manager
Community Manager
We have a spare TRC6 from an SX10 that was removed and I want to use it with another SX10. I tried to use it, but it doesn't work, the batteries were replaced.
Is there a way to reset the remote to work with another codec, or should it just work?
Thank you in advance.
Hi, thank you for your answer, there's no table connected, so I've checked the batteries again and it was that, all the ones I had at hand were exhausted.
Thank you again!
Greetings
Jonathan Schulenberg
The remote is infrared so there is no reset or pairing function. The other SX10 does not have a Touch 10 panel connected to it, correct?
Thank you again!
Greetings
