03-31-2006 10:52 AM - edited 03-15-2019 04:14 AM
Trying to figure out how to get the ring types of saxaphone, chirp, etc etc rather than the ring 1, ring 2, etc list on secondary lines. If I have multiple lines on my phone can I set the second, third lines to be one from the chirp,saxaphone, etc list that is different from that on my first line? Users want to be able to set different rings for different managers/bosses but the phone seems to only allow default or the list of ring 1, ring 2, etc. for the additional lines on a phone. I have been playing with this on a 7960. Thanks.
03-31-2006 11:35 AM
In TFTPPath folder locate RingList.xml file and DistinctiveRingList.xml file, compare the 2. If the DistinctriveRingList.xml file is listing the "Ring 1", etc, delete the file, copy the ringlist.xml and rename it to distinctiveringlist.xml.
Chris
03-31-2006 01:30 PM
did that and it still didn't work...reset my phone, etc, Had to restart the tftp service and now it is working. Thanks.
03-31-2006 01:50 PM
Very good.
Please rate the post if it was helpful!
Chris
