SDK sample services work without CallManager
benwymore
Hello All,
I've downloaded the Cisco IP Phone Services SDK. From looking through the documentation, it looks like, if I don't want to do anything related to telephony (for example, I just want to run the "clock.asp" sample), I should be able to purchase and configure a 7970 phone and run the clock sample service on the phone without owning a CallManager server. Is this correct?
-Ben
a001b20043809
Yes. IMO, you must only create a url for a ipphonemenu that point to this sample service. In The SDK there's a CallManager Simulator, but i don't know if 7970(i tried with the 7960 model...it works fine...but some limitations...)is supported.
Hope that helps,
Vitor
If you search the dungeons of this board, you'll find that people have managed to get the simulator working with other phone types.. it's just important to put the right files in the right directory since the phone makes a TFTP request to get its configuration and load its firmware.
Hi Stephan, thanks for your reply!
When you say "the simulator", you mean the CallManager Simulator?
Yes :)
