Setting Syslog on DMP using Advanced System Tasks - 5.2.3 Not working
marc
From the Users Guide - 5/31/2011
Page 296
It says we can create a Request Type
Set
init.syslog=on&init.syslog_collector=<DMM_routable_IP>&mib.save=1
&mng.reboot=1
The above does NOT work on 5.2.3 4310 or 4400.
Is this a bug?
This does work and it sets the Pop Message Enable to Yes also.
notify.syslog=on&notify.syslog_collector=<DMM IP>&notify.pop_enable=true&mib.save=1&mng.reboot=1
Hope that helps others.
Marc Alumbaugh
marc@rockingchairsoftware.com
Fabrizio Pedracini
Hi Marc,
thanks for pointing that out. Indeed the init.syslog* in 5.2.2 and earlier are now notify.syslog* in 5.2.3 so the last set string you wrote will actually enable syslog on 5.2.3. The doc has to be updated.
cheers,
Fabrizio
