Sip trunk between CCM 4.x and UC500
mirkomaffioli
It's possible to create a sip trunk between a CCM 4.x and a UC500 in order to use the CCM as pstn gateway and permit internal voip calls?
Mirko
Then yes,
- on the CCM configure voip trunk as per documentation
- on the voice GW configure DP so that call to certain numbers (hopefully you've ISDN) can go to CME
- on CME configure a voip DP with destination-pattern the numbers that are on the CCM, ipv4 address and codec g711u. Also configure a destinaion-pattern for PST calls having session target the other GW.
5 Replies 5
paolo bevilacqua
Are you using H.323 or MGCP with CCM ?
i've 3 gateway with H323
Bye
Mirko
Then yes,
What about If I'm usnig MGCP?
thanks,
thanks,
Only use H.323 or SIP for trunking.
