SIP Trunk between CUCM and SPA9000
dsuntama
Hi All,
I would like to know is it possible to connect SPA9000 with CUCM by using SIP Trunk ? How is the setting on both ?
Or is there any other way to connect SPA9000 to CUCM ?
Thanks very much
David
paolo bevilacqua
Should work, but I recommend you only use true cisco GWs for most reliable and feature-rich results.
How are you plannign to use it?
It should integrate fine and SIP trunk is the best way as SPA is all SIP with few other options.
You can use it completely independent as well just configure your translations on cucm.
Please rate helpful posts.
Baseer.
