SQL 2K patch error
azam_anwar
Level 5
Level 5
I'm trying to install SQL2K-ServicePack4.1-0-3 on a 4.1(3) CM, following an upgrade from 3.3(3).
However, i get the following message when trying to run it:
CCM 3.3(3) is detected. This Service Pack is not supported for CCM 3.3(3).
Anyone know of a workaround?
jbarcena
Level 11
Level 11
You seem to be hitting CSCsb43167.
Workaround:
Go to Registry and delete the following registry
This is all safe to delete:
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\CallManager\HealthCheck]
"HealthCheck-CMVer"="3.3(2)"
"HealthCheckVer"="1.0(1)"
"HealthCheckBuild"="03021404"
"HealthCheckSuccess"="Yes"
"HealthCheckRunDate"="2003-05-31"
Rerun the SQL2k SP4 installation.
//Jorge
