The SRST admin document says:During CallManger fallback, all calls to phones not in fallback mode will be routed to default destination. However, i cannot make it work.
The 3725 rotuer config is like:
call-manager-fallback
ip source-address 10.10.10.1 port 2000
max-ephones 1
max-dn 10
dialplan-pattern 1 9022... extension-length 4
default-destination 2000
Two CCM 7960 phones (2000 and 2001) fallback to the SRST. Phone 2000 is registered while 2001 is rejected because of the max-ephones=1.
When dialing 9022000 through the T1 Pri PSTN interface, phone 2000 rings.
When dialing 9022001, get busy signal. I was expecting to connect to the default-destination 2000.
When dialing 9022002, also get busy signal.
