Telephony commands not offered
cunninga
I'm trying to configure a 3640 as a VoIP to T1 PRI ISDN gateway. It's not offering me some of the telephony commands:
test(config)#dial-peer voice 1 pots
test(config-dial-peer)#port 1/0:23
^ (^ is under the o of port)
% Invalid input detected at '^' marker.
test(config-dial-peer)#exit
test(config)#dial-peer voice 2 voip
^ (^ is under the v of voip)
test(config)#voice-port
^ (^ is under the -)
Am I running a suitable version of IOS?
test#sh ver
IOS (tm) 3600 Software (C3640-IX-M), Version 12.2(8)T, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 14-Feb-02 17:43 by ccai
Image text-base: 0x60008930, data-base: 0x60BF0000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
test uptime is 2 days, 17 hours, 12 minutes
System returned to ROM by reload
System image file is "flash:c3640-ix-mz.122-8.T.bin"
cisco 3640 (R4700) processor (revision 0x00) with 98304K/32768K bytes of memory.
Processor board ID 26875901
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
24 Serial network interface(s)
1 Channelized T1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
The code you are running will not support voice-ports. I think "-ix" is Gatekeeper. You need IP Plus as a minimum
rlyons
I can't put my hands on an IOS name explanation document conveniently but to check the capabilities of your IOS use context sensitive help. After the "dial-peer voice 2 " command enter a "?". This will display your options. If VoIP is not one of your options your IOS feature set probably doesn't it (voip).
At the enable prompt type "show voice port summary." That will display your voice ports as the router understands them. If you do not see "1/0:23" your router does not see it. If you don't see it then check the configuration of the controller. You must have the controller setup for PRI voice for the router to understand that it will be a voice port.
Bob Lyons
Bob,
Thank you for your response.
test(config)#dial-peer voice 2 ?
pots Telephony
test(config)#end
test#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
What do I have to do to set the controller for PRI? Here is the current controller config:
controller T1 1/0
framing esf
clock source internal
linecode b8zs
pri-group timeslots 1-24
and I also have:
interface Serial1/0:23
no ip address
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 30000
isdn bchan-number-order ascending
no cdp enable
