The problem of cisco vpn disconnection in mobile phone home screen mod
tdwer
Hello
I just managed to get cisco vpn up and running on my ubuntu 20 server.
When I connect to my cisco vpn user using a mobile phone, if the mobile phone is idle, my VPN will stop the traffic after a few minutes and I will have to log in to my username again from the beginning.
Can this problem be solved through server configuration?
Thank you for guiding me.
Thank
smartjenny
Fix Cisco VPN dropping on mobile:
Server configuration:
Enable NAT Keepalive (send periodic packets to keep connection alive)
Enable IKE Keepalives (verify connection with IKE protocol messages)
Increase User Idle Timeout (prevent server from terminating inactive sessions)
Mobile device settings:
Check power saving settings (may disconnect Wi-Fi/data)
Check VPN client settings (disable options that disconnect VPN when idle)
Consult Cisco documentation or support for further assistance.
the Harford Fire Blog stands out as a crucial resource.
