translation rule help
kbrown
All -
I'm really struggling with one particular translation rule; in particular:
translation-rule 10
rule 1 /(..........\)/ /1\1#/
The goal is that when the system is presented with 10 digits, it will pre-prend a 1 (force long distance) and append the # to complete the call.
The # is required to end the digit string on two of my dial peers. If I don't include the # the system will continue to wait for more digits for a long, long time.
I'm concerned that the system isn't adding the #, but simply interpreting it as a wildcard...
Any suggestions?
johncaston_2
Can't help you too much with the translation rule but if you want to reduce the time it waits, reduce the inter-digit timeout, which defaults to 15 seconds in CCM. I reduced mine to 5 seconds and users haven't complained - at least that way you can avoid having to worry about the #
Thanks for the response.
In this case it's not a matter of the interdigit timeout. I have a CME system that has a pair of FXO ports tied to a GlobalStar sat phone (GSP-2900). The sat phone expects a trailing # to be sent at the end of the dialed digit string.
Because we have other FXO ports on the system that do not require this - and I want the user experience to be consistent regardless of which port is available... I need to translate the digits only when they are going outbound on the two sat phone ports.
Maybe that will help others understand the quandry.
