Trunk connection with E1?
asoil
Need to connect two PBXs with PRI using access routers. How would we achieve a 'trunk' connection between the two PBXs, is the 'Network Side ISDN PRI' the appropriate feature ?
Thanks.
5 Replies 5
icabrera
Level 4
Level 4
Hello, if you're going to transport propietary signalling throught this connection between the PBX's (trunk connection) you should use the "Circuit Emulation over IP" feature with the network module for this feature:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a00801ee181.html
But if you only wants to transport calls (toll bypass), connect the router with the PBX normally and configure the dial-peers to redirect the desired calls to the other PBX. You can see an example at:
http://www.cisco.com/application/pdf/en/us/guest/products/ps499/c1237/ccmigration_09186a00800e16ca.pdf
Thanks for your message. The second option is more like what I want. It user qsig, can I just use pri-net5, in case qsig is not supported ?
Thanks.
Hello, you can use pri-net5 too.
Sorry to bother you all. I have seen in a config that connection plar has been used, I thought you can use plar only with fxs/fxo ans E&M. Has anybody seen it work with e1?
Thanks.
