Unity Connection 12.5(1) to 15.0 upgrade
Bill
I am planning on upgrading Unity Connection from 12.5(1) to 15.
Specifically from 12.5.1.19017-4 to 15.0.1.11900-14
I am thinking an in-place upgrade.
But first I need to increase the RAM.
Disk and CPU are ok.
Just wondering if any caveats I can expect?
I will run the pre-upgrade check (have not done that yet)
Not on the specifics of what you asked about. Running the pre-check will give you more information. You should run that as soon as you can to find out if you need to do anything else than adding more RAM.
Response Signature
