07-01-2004 10:54 AM - edited 03-13-2019 05:30 AM
Hi.
i try upgrade publisher to 4.0.1
after start setup have message box:
"Cisco CallManager
MsiOpenDatabase:Return Code: 110:The system cannot open the device or file specified."
Any Ideas ?
Nikola
07-01-2004 11:40 AM
are you installing from the console, VNC or Term Service?
Make sure you are not using Term Service and that there are no open term service connections. You may want ot reboot the server before running setup just to make sure.
Kevin
07-01-2004 01:42 PM
thanks for response
install attempt making immedatly after reboot server from console.
tomorow i check install without running terminal service.
nikola
07-04-2004 06:58 AM
07-04-2004 02:12 PM
Did you run the Upgrade Assistant Utility???
07-07-2004 05:45 PM
This is in the install log:
07/04/2004 18:43:06.738 CCMSetup.cpp fnGetPackageName PackageName: "E:\\Cisco CallManager.msi"
07/04/2004 18:43:06.738 CCMSetup.cpp fnGetPackageName Function ended.
07/04/2004 18:43:06.738 CCMSetup.cpp fnGetPackageInfo Function started.
07/04/2004 18:43:16.452 CCMSetup.cpp fnGetPackageInfo MsiOpenDatabase: Return Code: 110: The system cannot open the
looks like there is an issue with reading the CD. What platform do you have? Is CD that is insered into the drive actually a DVD?
Kev
