11-24-2005 01:57 AM - edited 03-13-2019 11:20 AM
All phones keep rebooting and the CPU on the callmanger is running at over 80%. What traces can do to see what is causing the phones to reboot?
11-24-2005 02:05 AM
open taskmanager and see what is causing the cpu to spike - this is probably related to the phone issue
what do u mean by rebooting? do the phones ever register then unregister or are they stuck trying to look for a callmanager.
If the issue doesn't clear up soon, I'd suggest calling tac.
11-24-2005 02:22 AM
Thanks for your help.
on the taskmanager, sqlserver . ccm.exe and cTI manager are using most of the CPU. The phones are just restarting (not re-registering) on my ip communicator it says "High traffic"
There are over 1000 phones here and they are all on 1 voice vlan
11-24-2005 03:42 AM
Hi, have you tryed to stop and start the ccm services, f.ex tftp etc ?
You will probably se a lot of "device unregistered" in event viewer, but is there any other events of interrest ?
Perhaps you have found a solution on this by now ?
br
Runar
11-30-2005 10:29 AM
Did you ever find a cause/resolution to this, we are experiencing the same issues and are not able to determine the problem as of yet...
