05-20-2009 09:45 AM - edited 03-13-2019 06:23 PM
We have a Bogen overhead paging system and would like to play some music from the Cisco system. It would be for playing Brahms Lullaby when a baby is born. We currently use the phone system to access the paging via a LS port on the back of our 2821 router. We use a PCM2000 w/zones for paging. Have you all ever had to setup anything like this?
05-20-2009 10:28 AM
One option would be to setup an on hold source with a .wav file of Brahm's Lullaby. You could then assign this MOH to a DN, call the paging system from the DN and press Hold. You could also set this up using an IPCC auto attendant script.
Hope this helps.
Brandon
05-21-2009 05:24 AM
The first option MoH source worked great.Thanks for the help Brandon
