Use Call Manager to play media over a paging system.
peterunion
We have a Bogen overhead paging system and would like to play some music from the Cisco system. It would be for playing Brahms Lullaby when a baby is born. We currently use the phone system to access the paging via a LS port on the back of our 2821 router. We use a PCM2000 w/zones for paging. Have you all ever had to setup anything like this?
Brandon Buffin
One option would be to setup an on hold source with a .wav file of Brahm's Lullaby. You could then assign this MOH to a DN, call the paging system from the DN and press Hold. You could also set this up using an IPCC auto attendant script.
Hope this helps.
Brandon
The first option MoH source worked great.Thanks for the help Brandon
